ABS light + Reverse lights - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-01-2014, 11:39 PM Thread Starter
hey just got a 95 psd couple of small issues
abs light is on i changed VSS scanned with cheap scanner no codes not sure if i have to disconnect batterys too reset or should i be looking at wiring ect.
also with headlights on when i move the shifter past reverse the back up lights stay on and if i switch headlights on/off the lights turn off. im thinking it is a switch sticking on. if anyone knows location or which switch it may be would be helpfull
and has a mega fuel leak 15-20 drops after long drive have not looked into it but sure will need new o-ring in fuel bowl valley area filled with fuel
thanks
flexy04 is offline
post #2 of 4 Old 02-02-2014, 06:55 AM
I'm tackling a fuel bowl leak as we'll and now that I've taken fuel bowl it turned out they had rigged "water in fuel" sensor and broken bowl where it threads.
Good luck.
Check orings on drain
Hoses
Fuel sensor
Good luck!
i has a diesel.
junior9102 is offline
post #3 of 4 Old 02-02-2014, 07:20 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Codes for the RABS are not found using a scanner. To read the codes, see my post in this thread: ABS light continually flashing
Cheers!
Patrick Feeley is offline
post #4 of 4 Old 02-02-2014, 10:20 AM
midnite rider's Avatar
Quoted: 285 Post(s)
check plug and wiring on rear axle corrosion gets in on comes the light. had to replace 18 inches of harness plus the plug kind of a common thing
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
