Injector O-rings - Ford Powerstroke Diesel Forum
Old 10-18-2008, 10:40 AM
Injector O-rings
How do you know if the injector orings are going bad?
Thanks
Mike
Old 10-18-2008, 10:46 AM
idk
but heres a free bump for ya!!!!
i would like to kno to b/c mine mite be bad ???
Old 10-18-2008, 11:47 AM
Cynic
Oil usage, low(er) performace, and more. What problems are you having?
Old 10-18-2008, 11:51 AM
Blue smoke when I first start in the morning and runs fine after that sometimes rough idle at start also.
Old 03-04-2009, 07:07 PM
Think mine may be bad. I smoke blue at idle sometimes a little but if it is warmed up alot at idle. Could it be the orings? Using alot of oil.
Old 03-04-2009, 07:10 PM
duct tape & zip ties
Could be the O-rings, or could be valves, or there is a slight possibility of it being a cracked injector cup.
But I would be more likely to say the O-rings.
Old 03-04-2009, 07:13 PM
Thanks I look at changing them this weekend.
Old 03-05-2009, 03:20 PM
That is a typical diesel start in cold weather.Ford,dodge,gm all the same. Partially burn diesel is the blue. I haven't seen a diesel that isn't rough for a few seconds when cold.
Now blue all the time when warm isn't good.
