Time for a clutch - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-30-2014, 10:21 AM Thread Starter
Time for a clutch
My 1996 F350 is finally needing a new clutch in her. She's starting to slip a little in 4th and 5th gear. Do ya'll have any reccomendations on clutches? Truck is used primarily to pull a gooseneck and isn't really turned up much at all. Is there anything else that needs to be done when installing a new clutch? Flywheel need any attention? Thanks guys!
blueraid is offline
post #2 of 3 Old 01-30-2014, 12:04 PM
Quoted: 44 Post(s)
If it's the original flywheel, get RID of it. The OEM dual-mass is a time bomb; when the two masses separate, the small parts released can grenade your tranny case. Replace with a single-mass, one made to match the clutch.
madpogue is offline
post #3 of 3 Old 01-31-2014, 06:16 AM
Quoted: 2 Post(s)
Feel free to check us out and if you have any questions don't hesitate to call.
http://www.southbendclutch.com/ford_catalog.html
Peter
South Bend Clutch is offline
