Fuse 22 Blowing
It is late and I have had a long day. I believe I have a fuel heater problem. (Blowing fuse 22) I've read through many threads and I am going to find this fuel heater wire and disconnect it in the morning.( Hopefully problem solved.) So, my real question is: Is the heater a dealer item? I was unable to find it on napas web site. And about how much is it ($$$)?
Thanks, Jesse Note: Chiltons manual sucks! |
it is a dealer item, just unplug it and leave it unplugged wont hurt anything not to work
Thanks! I grabed a beer and a flash light and was going to take of it now, but it is raining. So I have something to start my day off with tomarrow.
yeah, its actually pouring where we are. where abouts in bonneylake you live anyway?
I'm behind the new lowes in The BrookWater development.
Ok, I'm am looking at the fuel bowl on the drivers side. Down where I can only squezze two fingers. There are two wires. I am assuming that I should be removing the top one. So I attemped to remove it. I tried to use needle nose pliers and a screw driver. Before I commit to creating any damage am I doinng this right?
theres a thread here somehwhere on how to update the heater element to a newer version. Unless it gets really cold, I'd just leave it unplugged.
Yes, I understand. I am just making sure I am unpluging the correct wire and that it just unplugs ( doesn't have a funcky twist Or something). If this is not the reason for my fuse blowing I don't want to break a good part.
yes it just unplugs.. IIRC it is a white plug connector. it is on the back side of the fuel bowl.
wrong moel john, his is a 96 , its a single wire connector on the side on obs body, i think it is the top one and it just unplugs , but sometimes is a bear to get unhooked
ah.. didn't look at the forum...
