Squeaky engine Noise? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-02-2008, 03:13 PM Thread Starter
sk3322's Avatar
Everytime I start up my truck now regardless or warm or cold start up, it squeaks very loud under the hood. It used to only do it on cold start ups, but now it is constant and even does it when I'm driving. I'm not sure what it is, hopefully a quick fix?
1997 7.3 F250 A/T, AFE Stage 2 intake, 3" DP to 4'' stright piped exhaust , pyro-boost-trans, leveled on 33's
sk3322 is offline
post #2 of 12 Old 10-02-2008, 05:03 PM
Shade tree mechanic
95dieselsmoke's Avatar
squeak as in maybe a belt going bad sqeak?
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #3 of 12 Old 10-02-2008, 05:05 PM
1badpsd's Avatar
could be the idler pulley going out or maybe ac compressor bearing or as stated above could just be belt fixin to break
Caylon Golden24
[B]01' F-350[B] ccsb dually 4x4 BTS
S475,300/200,SRP 1.1,h11's, DI headers and a few other parts
01' F-350cclb single wheel swap 4x4 "tow hoe" 250/200's, modded h2e, SRP 1.1, headers
00' f-250scsd 695.8hp
1badpsd is offline
post #4 of 12 Old 10-02-2008, 05:08 PM
Shade tree mechanic
good call. throw some belt dressing at it and see what happens
MATT
post #5 of 12 Old 10-02-2008, 05:26 PM
Powerstroke Techie
forddieseldoctor's Avatar
ick belt dressing is the worst thing you can do.
VERY BAD IDEA!!!
simply some silicone lube will tell you if it's the belt. and then replace it.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #6 of 12 Old 10-02-2008, 05:34 PM
Shade tree mechanic
VERY BAD IDEA!!!
good to know. never heard it was bad for it. just curious, why is it bad?
MATT
post #7 of 12 Old 10-02-2008, 05:40 PM
Powerstroke Techie
i'm not totally sure what happens, but i've seen it put on and it only makes the noise worse, My guess is that there's something in it that reacts badly with the new belt materials. Also napa and carquest belts all seem to come back making squeaking and or chirping noises. I know that most do it yourselfers don't like to use oem parts, but there are certain parts that simply work better.
Meet Double Aught
2000 F250
post #8 of 12 Old 10-02-2008, 08:15 PM
Cynic
Dirk's Avatar
Does it do it when you shut the engine off? Like a sec after the motor stops moving?
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #9 of 12 Old 10-02-2008, 09:14 PM
Shade tree mechanic
hey dirk, my buddies cummins does that. never figured it out. whats it mean?
MATT
post #10 of 12 Old 10-02-2008, 10:12 PM
TxPSD9673's Avatar
all cummins do the squeak at shutdown, but on the squeaking i got the same problem and i know what it is. It is in fact the idler pully well actually part of the metal piece barely touches i mean BARELY touches another metal surface and it makes the squeaking. its on the passenger side of the belty system on the farthest left part take a look and youll see what im talkin about
NEW TRUCK
-Dakotah 2000 Patriot Blue Dodge 2500 Auto 24v Cummins 4x4 578HP/991TQ
7" Black Cat, BHAF, FASS 150, Built Trans, BW 66/74/14, DDP 7x12s, ARP Studs, TST COMP, EJWA CTS,
3'' Lift, 35'' BFGs, 16x9 Black Moto Metals, Smoked Out LEDs, 6k HIDs, Ranch Hands, ect.
TxPSD9673 is offline
