Can diesel gel up after up to temp or did my fuel pump crap out? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-07-2014, 07:07 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well after 2 hours of p--sing with my truck to get it started yesterday in -15 i let it warm up before i started driving and it was pretty close to operating temp and then all of a sudden it started shaking almost like i had a loose tire or unbalanced drive shaft.
I pulled over into a parking lot and it was running like crap and checked my fuel pressure, it was down to like 20 psi so i shut it down and got a ride back to my place. What could have caused this?
Keep in mind i have e-fuel with fuel bowl delete so i have a super duty fuel pump and an aftermarket FPR. When i turn the key on the FP goes up to about 65 but slowly bleeds off and the pump sounds pretty bad like its pushing slush which is what made me think of gelling but it had been running for a good 30 mins and the temps were almost into the "normal" section of the coolant gauge.
I woulda imagined by then the fuel in the fuel tank had been sufficiently warmed up or could it still gel up even after that long?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 01-07-2014, 07:09 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
you answerd your own question...gelled. I'd wait for it to warm up and see, dont put the cart before the horse (i've dont what a few times) thinking you have something else wrong before you rule that out
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 7 Old 01-07-2014, 07:34 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
No i didnt, i asked if it was possible to gel after the engine was damn near up to temp. I just said the fuel pump SOUNDS like its pushing slush but it could just be what it sounds like when it craps out because ive never heard one crap out.
I was just trying to rule out possibility of gelling up to temp short of tearing my whole fuel system apart in the freezing f-ing cold before i started troubleshooting other causes
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 7 Old 01-07-2014, 07:40 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
yes, even after getting up to temp it can pump gelled/waxed fuel from the tank that wasn't warm...like running water through a frozen pipe/hose ice chunks still are there and can block up the passage. happened to dad's case skid steer this last weekend I had to tow him home at like .5 mph
dannanw is offline
post #5 of 7 Old 01-07-2014, 07:42 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
ULSD Cold Weather Information
just wanted to share this link, I found it two weeks ago while trying to figure out gelling on our backhoe and my truck and dads 7.3
dannanw is offline
post #6 of 7 Old 01-07-2014, 07:57 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well the OBS is set up as regulated return so the fuel actually gets heated up and sent back to the tank so thats why i just found it hard to believe it gelled up after running for a good half hour but it being -15 i suppose weirder things could happen
Thats a good link, sure makes you miss the old HSD and LSD
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 7 Old 01-09-2014, 08:54 AM
Quoted: 48 Post(s)
That info is over six years old. It would be useful to see an update of the characteristics of ULSD now that it's been out in the wild this many years. I don't think we've seen quite the gloom and doom and mayhem that the article seemed to forecast.
madpogue is offline
