Door hinge bushings worn - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-30-2013, 05:08 PM Thread Starter
The driver's door hinge bushings are worn so you have to lift the door to get it to latch closed. How can I repair this problem?
TritonStablesNC is offline
post #2 of 7 Old 12-30-2013, 09:24 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Get some new Door Hinge Pin & Bushing kits (need 2 per door). Cut out the old ones (do one at a time and support the door!) and install the new ones. Motormite HELP! 38410. Cheers!
Patrick Feeley is offline
post #3 of 7 Old 01-13-2014, 11:15 AM
97bluepowerstroke's Avatar
I found it hard to get the old pins free while on truck.. I unbolted the whole door. Switch them where I had room to work and reattached and adjusted
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
post #4 of 7 Old 03-13-2014, 07:32 PM
Replaced both sides on my 95 I used a reduplicating saw and cut each pin one at a time. Be sure to support the door from dropping down
95 f250 beast is offline
post #5 of 7 Old 10-02-2014, 07:21 PM
doctor41baller's Avatar
NEWB: Where yall get the new door pins?
doctor41baller is offline
post #6 of 7 Old 10-03-2014, 08:27 AM
Quoted: 13 Post(s)
Almost any auto parts place that carries the Motormite HELP! line of products should have them (see my post above). Cheers!
post #7 of 7 Old 10-03-2014, 10:11 PM
Thanks for the reply. Going to check out napa tomorrow. Got to go there anyways see about air filter mod. Trading the k&n that's on it
