Fuel in radiator. HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-23-2013, 07:24 PM Thread Starter
Hi. I noticed fuel in my radiator today and I was wondering of it is ok to drive tonight because it's a plow truck and I need to go plow. PLEASE HELP!!
1997fordf-350 is offline
post #2 of 7 Old 12-23-2013, 07:32 PM
troykimber's Avatar
sounds like injector cups maybe? I wouldn't drive it like that though...
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
post #3 of 7 Old 12-23-2013, 07:36 PM Thread Starter
So it's not safe to drive?
post #4 of 7 Old 12-23-2013, 08:09 PM
theforeman57's Avatar
Quoted: 4 Post(s)
post this in the 94-98 general forum. also, fuel in coolant means that there is now coolant in the fuel, sounds like a injector cup is cracked.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #5 of 7 Old 12-23-2013, 08:27 PM
Long Member
TMAG6.0's Avatar
Wouldn't it go high pressure to low pressure? I would think there is always more pressure on the fuel system than the cooling system.
Just thinking out loud.... or in print
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #6 of 7 Old 12-24-2013, 07:47 AM Thread Starter
I loosened the cap and it seemed to help because it's not leaking as bad. Is it safe to drive until after the holidays?
post #7 of 7 Old 12-24-2013, 01:10 PM
Long Member
TMAG6.0's Avatar
i dont know the 7.3s very well at all, never had one. i would say common, sense wise, if theres not a ton of fuel in the coolant and its running fine u should be ok. Baring a total failure.
Right now she is telling you somethings wrong. Safe bet is park it. Its a hard choice when you have obligations.
Maybe this bump will get some 7.3 folks to chime in
good luck
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
