hey guys I have a little problem that just started happening yesterday I noticed as I was driving yesterday that I had a mixture of white and black smoke coming out of my stacks and sometimes it was just solid white. So I threw in some injector cleaner. Today I started the truck up ran it very easily for a while then got on it to see if it would do it again and all black smoke luckily and a little more than usual. Then I shut the truck off to go into a store came back turned it on started driving and ALL white smoke I looked in the reflection of a store window and brake torqued it for a second and all that came out was white smoke! It seems to be going back and forth from solid black to solid white to a mixture. I have no idea what is going on.
![]() PLEASE HELP!-Matt |
Anyone
it sounds like your getting water in the combustion chamber some how thats what white smoke usually means right maybe a gasket or seal or something is makeing a plan to FAIL lol as it would be its a EPIC FAIL!!! as far as where to start i have no idea
yeah Im not sure if my injectors might be starting to fail, coolant in the cylinders or what I have no idea
anyone got any ideas on whats going on?
I would first start with looking at the oil, see if it's got bubbles in it, then look at coolant and see if there's oil mixed in with it. Then if there is, you know you got a problem.
yeah the oils fine Im changing it this weekend too, and I checked the coolant no oil in it.
turbo, id check that
What should I check with the turbo? excessive oil?
