OIL IN MY COOLANT - Ford Powerstroke Diesel Forum
Old 09-10-2008, 02:54 PM
OIL IN MY COOLANT
I pulled my oil cooler out on sunday and re sealed it and it fixed the problem. Not loosing any more oil. Thank God to because that was a pain. I did it at work and it ended up being a pretty late night, so when I was done I just threw some coolant back in it and went home. But now I still have a pretty good amount of oil in my coolant. What would be a good way to flush it out?
Old 09-10-2008, 03:02 PM
<-Day Of Fail now SOLD
I found this in another forum maybe it will help.
coolant change. - Diesel Forum - The Diesel Stop.com
Old 09-10-2008, 04:18 PM
lukecline
Guest
Posts: n/a
i flushed mine a bunch of times and used a little powerdered dishwasher soap. I picked up the soap tip from an old mechanic. It seemed to help get the oil out better than using just water.
Old 09-10-2008, 04:34 PM
ADMIN AND TECH
we were always told to use cascade dishwashing stuff to help ,it is hard to get out
Old 09-10-2008, 04:36 PM
Jon
Guest
Posts: n/a
Yeah
I hate to agree with scuff but that is good stuff. Also look at simple green.
Old 09-10-2008, 09:44 PM
Send a message via AIM to ford_trck
When we do it on big rigs we use cascade powdered dish soap. Usually we flush it 3-4 times before we get the fuel or oil out of the cooling system. We drain it, fill it with water and soap, run it for a 20-30 min, drain again. Look at whats coming out and then decide if should be soaped again. The last time we put just water in to help get all the soap out. Then fill it with coolantl.
Old 09-11-2008, 02:00 PM
Thanks for the input. My boss also said to try cascade soap and a small amount of mineral spirits to help break down the oil. . So I guess Ill give it a try. Looks like Ill be at work again this Sunday. Makes life allot eaiser working in a pit.
Old 09-12-2008, 07:45 AM
Thumbs up
Thats the same way we flush out a coolent system when the oil cooler goes out.
Old 09-12-2008, 08:37 PM
We have to do what works and well that system works it's just time consuming
Old 09-16-2008, 04:48 AM
Cool oil in coolant
ford 7.3 1992, I had oil in the coolant so took out the oil cooler and replaced the o rings. This seemed to stop the oil leak but several months later it started again oil in the coolant. I have taken out the cooler again .. should I get a new one.... is their a test to check for leaks?.. besides ford any place to buy one??
I did get one from a salvage yard but their is metal inside it????
thanks
