rough idle - Ford Powerstroke Diesel Forum
Old 09-08-2008, 02:37 PM
Angry rough idle
Today I started my truck after just a few seconds started running really rough and cel came on. It has done this before but normally I shut it off and turn back on again and it is fine. today it did it everytime so truck is sitting. I tried taking my programmer out and same thing. I have replaced cps, could that be it again. please get back to me.
Old 09-08-2008, 07:58 PM
Shade tree mechanic
checked all the basics of course? fuel filter? oil level? does it rev up when you hit the accelerator or does it sputter?
Old 09-08-2008, 08:23 PM
have not really checked anything would just like to get it to my farm so I have somewhere to work on it. The programmer I had in there has a code reader showed po472 but thats because I have my epb valve unhooked and the other po603 internal ctrl mod kam error, don't really know i suppose it could be many things. my truck is a 95 f250 with 220000 on it i have done injector o rings and cps. that is about it. havent had to stick much money in it. never have had issues with fuel filter that caused it to act up. I will check oil and try the accelerater to see how it reacts in the morning.
Old 09-08-2008, 08:25 PM
I am going to try my buddies scanner also to see if that reads anything different
Old 09-08-2008, 08:30 PM
Shade tree mechanic
keep us updated man. if you have time check the fuel filter, see if it aint way dirty. good luck
Old 09-09-2008, 08:13 AM
scanner does not communicate with anything plus would a dirty fuel filter throw a cel.
Old 09-09-2008, 08:14 AM
accererating it changes nothing still misses with cel on
Old 09-09-2008, 08:15 AM
ADMIN AND TECH
if i had to guess , i would say short harness under valve cover or a possible icp /ipr rpoblem, is the oil in good shape and full, need to get codes pulled before doing much more
Old 09-09-2008, 08:40 AM
My '94 Powerstroke was idling pretty rough when I got it...but it seems better now...I replaced the oil and filter-also the nut fell off that holds the solenoid on the IPR...you might want to check that...
Old 09-09-2008, 07:27 PM
My truck is running more like its only hitting on 7 cylinders. put scanner on it and it said that it coundnt comminicate with my truck could it be a bad computer.i think mines original the number on mine is TEE5. were these ones known for problems and is their a better one to put in thats not to much.
