Belt came off, not even shredded, but metal is? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-16-2013, 11:31 AM Thread Starter
KS_
Quoted: 22 Post(s)
My power steering and brakes completely went out. Luckily I was at home. This metal piece is completely shredded and looks like it'll be fun to replace. Anyone know what this thing is called?
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 5 Old 12-16-2013, 05:59 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Your pulley bearing failed (and the pulley probably melted from the heat ... at least that's what mine did on the 94). I would call it the Alternator bracket, but who knows what Ford might call it. Are you sure you can't just remove the remnants of the pulley bushing and bolt and replace the pulley? Cheers!
Patrick Feeley is offline
post #3 of 5 Old 12-16-2013, 06:13 PM Thread Starter
KS_
Quoted: 22 Post(s)
My first thoughts was that it was stuck in there and there was no gettin it out. But I tried to take it off and it came right off. Found my pulley where I was parked before pulling in the garage. So that was the problem:/ I just cant find that screw anywhere but its too late to call napa or check an auto yard... I feel stupid lol. It was a lot easier than I thought
KS_ is offline
post #4 of 5 Old 12-17-2013, 01:29 PM
Quoted: 15 Post(s)
Gert a new idler from Ford as it will come with a new bolt. I can't remember whether its grooved or smooth, but I got replacements for about $18. Cheers!
post #5 of 5 Old 12-17-2013, 06:14 PM Thread Starter
KS_
Quoted: 22 Post(s)
I got it alk figured out. The dealer wanred 49 dollars for the thing that came with the screw. So I said screw that. Went to a bunch of junkyards that didnt have squat. I went to a pick your own parts place called LKQ and got one off a 99 f150. Bolt was just a 1/16 of an inch shorter but it worked fine. Well worth $6
KS_ is offline
