Throttle no response
881 views 2 replies 2 participants last post by  95sorensonOBS
#1 ·
This has been a problem for quite some time, when I start the truck I can push the pedal down and nothing, I have to let the pedal slip and slam up a couple times then it's normal, anyone ever have this problem? It comes and goes and only after I start the truck
#2 ·
You might check the idle validation switch (IVS) on the pedal assembly (the two-wire one) to see if it is intermittent. Sometimes it can be helped with some electrical contact cleaner. Cheers!
