1997 PSD no fuel pressure - Ford Powerstroke Diesel Forum
Old 09-04-2008, 05:21 PM
Question 1997 PSD no fuel pressure
1997 PSD shutdown and will not restart. No fuel pressure at test port. filter bowl is empty and will not refill. With both rubber hoses disconnected at the two steel lines that run up to engine, there is no fuel flow with KOEO or while cranking. Question is, is there an electric pump in each tank or elsewhere? I've read a few threads and seems like there is. Truck has dual tanks and no fuel flow in either tank switch position. Don't want to change mechanical pump if not necessary. thanks in advance
Old 09-09-2008, 06:58 PM
Sounds like lift pump, to me.
'97 PSD have a cam shaft operated lift pump on top of engine, between turbo and fuel filter bowl, no pump in tanks. It pulls fuel from tanks. This pump is easy to change, no matter what the manuals say, you don't have to remove turbo. Just remove turbo inlet chamber, loosen filter mounting bolts, hardest part is disconnecting hose clamps, fuel lines, I had to gently pry under pump bolt flange. I also removed fuel filter, flush bottom of bowl and clean with compressed air then install new filter. Also check return port on right side of bowl, there is a screen that could be partially plugged. Remove mounting screws and gentely pull out of bowl, do not drop o-ring or screen in valley of engine.
I had a loss of power when trying to drive my truck, lift pump fixed my problem. Pump could not supply enough fuel when accelerating.
Old 09-09-2008, 08:59 PM
Smile
Thank you for the reply, Since my post I have replaced the lift pump and small hoses with it. After a little bit of cranking the engine started and seems back to normal. Job was simple, did not remove turbo.
Old 04-30-2009, 05:46 PM
Sounds similar to what's happening with my 97 (see the thread I started earlier today). I'm new to Diesels. does anyone have pics or a good manual to get to help me with this learning curve. I've had the truck three weeks, and it's conked out on me as many times. Thanks
