fuel leak from valley - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-11-2013, 01:00 PM Thread Starter
ok i have a fuel leak in the valley and i can not find where it is coming from. i have replaced the fuel bowl about a year ago drain valve orings are good. i replaced all the lines from the bowl to the pump and replaced the banjo bolt seals about a week ago. the only other thing i can think of is the brass nipple on the front of the lift pump. is this a serviceable part it looks like i could take a spanner wrench and unscrew it. or is this pressed on
Bmoore84 is offline
post #2 of 8 Old 12-11-2013, 02:33 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Clean everything up as good as you can and check for a leak at the weep hole near the base of the pump (mirror and flashlight works good). Cheers!
Patrick Feeley is offline
post #3 of 8 Old 12-11-2013, 06:26 PM
977300's Avatar
I could actually see mine leaking with the cover off, from looking from right over the glow plug relay down at the base of pump fuel spraying from the hole. Bright flashlight helped a lot.
97 F-Super Duty 5 speed...T&S Performance Chip. More upgrades to come.
95 F-Super Duty 5 speed. The current project.
94 Dodge 2500 SOLD!
94 Dodge 3500 Sold to buy Superduty parts
95 Dodge 3500 Sold to buy more Superduty parts.
03 Dodge 3500 SRW, 4 door, 4X4, Cummins
Banks exhaust. Transmission upgraded.
977300 is offline
post #4 of 8 Old 12-12-2013, 07:13 AM
96f350powerstroke's Avatar
I just notice mine leaking fuel the other day. Was dripping down off the starter. Checked the valley and its definitely coming from somewhere around the fuel pump. I'm a Newbie when it comes to diesels, is there a complete kit I can buy that replaces the lines to and from, all o-rings, seals etc? I would like to take care of all the "problematic" potential leak points at the same time. Thanks for any and all info, and sorry for posting on your thread just didn't want to start a new one that's the same.
96f350powerstroke is offline
post #5 of 8 Old 12-12-2013, 07:16 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Dieselorings.com will become your best friend. He has all the kits to reseal just about everything on the truck at great prices and fast shipping
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 8 Old 12-12-2013, 07:18 AM
Quoted: 902 Post(s)
Feedback Score: 3 reviews
Not to mention customer service second to none.
Corey@CNCFAB is offline
post #7 of 8 Old 12-12-2013, 07:23 AM
Chapter Director
Quoted: 5 Post(s)
Well i have never had to deal with customer service so i suppose that speaks good of them as well
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 8 Old 12-12-2013, 07:23 AM
Thanks, Ill check it out
96 f350 powerstroke
6 position tuner
3" down pipe 4" turbo back
Newly built tranny, billet tourque converter, heavy duty clutches, shift kit
Stock motor with 189k
9" lift on 37" toyo M/t's
