A/C help!!!!!!!!!!!! - Ford Powerstroke Diesel Forum
Old 08-31-2008, 11:24 AM
it goes from hot to cold (cold isnt very cold) sometimes does it just need freon? and also i leave the fan on high and it is about as powerful as my 01 f250 on low so i need some help???
Old 09-01-2008, 06:58 AM
FYI, freon is not used, its R134A now. If you're having to add it regularly, then you have a leak that needs to be addressed.
If you are not having to add R134A, I would suspect the compressor.
