Electrical problems no start
I change the starter solenoid on the fender wall... change the ignition switch... I can jump across the solenoid and start the truck but i can't start it with the key.... all the fuses are good... ... any relay's or other solenoids to check... 97 f350 psd
i would say double check your ignition wires. maybe you forgot something or somethin got pulled out.
This might be a stretch but my 88 F350 had the same problem. There's a rod that runs down the top of the steering column that was bad. Wiggled it around and it worked.
