where can i find a v band clamp for a 94.5 psd - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-06-2013, 03:03 PM Thread Starter
I blew the clamp from turbo outlet to intake y pipe. I called Ford and its discontinued. Tryed napa, advance, pepboys, fleetpride, international dealer, Honda/import shop. Any ideas or partnumbers? Also is there seal or o ring between the turbo and y pipe? Thanks, rob
robhowardiii is offline
post #2 of 4 Old 12-06-2013, 06:54 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Yes there is a seal between the y-pipe and turbo:
Turbo Compressor Outlet to Y-Pipe O-Ring (94-early 99)
(Ford) F4TZ-9E436-A
(International) 1818372C1
Sorry, I don't have a part number for the OBS clamp, the only part number I have for a clamp is the early 99 clamp which is different due to the extra thickness of the cast aluminum y-pipe for intercooled application). Cheers!
Patrick Feeley is online now
post #3 of 4 Old 12-07-2013, 11:37 AM
Arcturus's Avatar
Really fast shipping from Bob aka Guzzle
F4TZ 8287 B Ford Turbo Outlet V-Band Clamp 1994.5 through 1997
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 4 Old 12-07-2013, 01:55 PM Thread Starter
Originally Posted by Arcturus View Post
Thank you so much. I looked online for hours to find that. thanks again, Rob
