HELP please...truck no go ??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-23-2008, 09:23 PM Thread Starter
Help anyone...stuck in gallup, NM trying to get to Oklahoma. Truck was running strong then just starting grinding and lost all power to the drive train. Pulled over and found that the carrier bearing looks like it went out. So I jumped back in and tried moving it, figuring I could go somewhere, started going then a big clang and grind and no motion, just grinding.
I just had a southbend clutch installed
1995 crew cab flat bed 5 spd 4x4
Southbend con ofe
afe stage II intake MBRP 4 inch TB exhaust
SD Intercooler, DIY Exhaust Brake
gloshift gauges, Dfuser 18k mod, IDM mod, BB mod
Dually conversion, 24 foot livestock trailer
Aaron Dickinson is offline
post #2 of 4 Old 08-24-2008, 07:31 AM Thread Starter
anybody have any ideas?
Southbend con ofe
post #3 of 4 Old 08-24-2008, 08:32 AM
Does it sound like it is coming from the clutch since you have had recent work done there? If you have any tools I would...
Pull the dust shield and have a look.
Pull the drive shaft and see if it will run the power through the tranny without the noise. If so fix the shaft.
04 F-550 CC 6.0 4x4 cab n chassis 4.88 XLT 193K
Money maker with utility bed.
97 F-350 CC 7.3 ZF-5 4x4 4.10 324K
Moves my stuff around.
Hardline is offline
post #4 of 4 Old 08-24-2008, 07:46 PM Thread Starter
ok..... started troubleshooting from the tranny back and found that for some reason my hub and wheel assembly was siezing up, ended up sheering off the studs on one side. I removed the axle/hub assembly as well as the differential cover and everything looks good. I still don't understand why that would cause the loud noises up at the tranny, but everything seems to work fine.
Thanks hardline...it gave me somewhere to start.
Southbend con ofe
