oil leak passenger side help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-28-2013, 08:21 AM Thread Starter
I know the truck needs seals on the heat exchanger. But it has a leak on the passenger side. At first thought it was the rear main. But there is oil on the starter nose area also. So I figured ask about trouble areas to check before hand. Never hurts to get educated. Thanks guys.
Btw this is my first post, and Im sure many more!
oldschoolrides is offline
post #2 of 2 Old 11-28-2013, 01:32 PM
Arcturus's Avatar
See if you have oil in valley. If you do it's prolly getting there via the weephole in the back of the valley.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
