noob question 4x4 dosent work at all need help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-23-2013, 11:29 PM Thread Starter
spartan-alteran's Avatar
ok is snowing like crazy out side I go to lock my hubs and shift my truck on 4x4 I cant I go under the truck and manually pull the shifter into 4x4 and now the light show up as 4x4 but the wheels arnt turning and shaft isn't turning and wen I try to go on 4x4 low dose the same I even tried by litarly manually shift her to 4x4 low also the shaft wont even lock up but neutral work well on the shifter note I have a f150 shifter on my f350 trany is a eo4d
wat you guys think it can be ?
could it be the linkage, transfer case or the EO4D
before this happened wen I shift it to 4x4 the shifter world act like if something wase grinding on it like gears so I think is the transfer case wat do you guys think ?and wat can I do to fix this
spartan-alteran is offline
post #2 of 2 Old 12-07-2013, 12:36 PM
Gertrude's Avatar
Send a message via Skype™ to Gertrude
Did u check the transfercase shift motor
Andy=23
Future Mods: Project Revive/Rebuild/Restore
Too many cars, not enough money.
Gertrude is offline
