Truck died after fuel filter lite came on - Ford Powerstroke Diesel Forum
Old 08-16-2008, 01:23 PM
I wasw driving my 96 F350 Crew cab power stroke home from a 160 mile road trip and the fuel filter light started flashing while climbing hills. It then came on steadily and the truck started to loose power. I went to pull to the side of the road and it died all together. I am currently running vegetable oil in the truck. I pulled the filter and cleaned it the best I could. I got nothing. I have it towed back to my shop. I pulled the fuel line by the left front wheel and used my suction gun to pull fuel through it. So I know it isn't the transfer switch or a clog in the the rear. It doen't seem to be getting any fuel into the filter housing. I changed the filter and filled the housing with fuel, and still nothing. Please help!!!!
Old 08-16-2008, 02:21 PM
psd
plug truck in and see if that will help.
Old 08-16-2008, 08:18 PM
I will try that in the am
Old 08-16-2008, 11:54 PM
psd
it sounds like there is a clog somewhere . so i thought if you plug it in, it would thin out the fuel.so the clogged line would blow through.
Old 08-24-2008, 04:17 PM
Have you checked your fuel pressure at the schrader valve? It could be the fuel pump, IPR, IPC sensor, HPOP, or low oil. That's all I can think of. A problem with the IPR or IPC should throw a code, but the others might not.
