Motor sound change and jerking - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-21-2013, 12:21 PM Thread Starter
97bluepowerstroke's Avatar
Ok.. 97.. stage 1.. d66. Built trans... some other stuff.. when drivin at normal throttle taking off or cruiseing it sounds like rpms jump and truck surges.. thought maybe throtle sensor... but on cc still does it.. changed fuel filter n cleaned bowl.. ran lucas injector cleaner.. still here. Thought was tc.. traans built got truck back today still does it... at half or wot it does not do it
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
post #2 of 6 Old 11-21-2013, 12:23 PM Thread Starter
Also on tach rpm doesnt noticebly change
What I have tried.
Unplug icp still does it.
Change filter n cleaned
Built trans.
Ran cleaner
Changing oil sat.
Changed cps
Checked throttle pos sensor
Lost now...
post #3 of 6 Old 11-25-2013, 03:04 AM
Camok10's Avatar
Have you thought of possibly Injector cups or a Boost leak?
Camok10 is offline
post #4 of 6 Old 11-25-2013, 03:31 AM Thread Starter
Boost iz running normal... no changes... dont knoe much about injector cups
post #5 of 6 Old 11-25-2013, 08:12 PM
Camok10's Avatar
I've personally never done them, but my friend has done a couple trucks with similar symptoms and the cups have been blown out.
Camok10 is offline
post #6 of 6 Old 11-26-2013, 05:58 AM Thread Starter
Lasy truck I saw with cup issues rolled hite smoke at idle like a 6.0 with egr ppproblems
