E4OD odd shifts. - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-14-2008, 04:03 PM Thread Starter
POWERSMOKIN's Avatar
E4OD odd shifts.
So, picked up my stroke the other day. its drives nice except for the shifting....
1st to 2nd is good, but 2 to 3 is TERRRIBLE! it will rev to 2600 with almost no throttle input, then i have to let off, and then it shifts, then i get back on the throttle, and it kicks onto OD after .5 seconds.
it seems to help if i toggle OD between 2nd and 3rd.... Not so high revving.
Does anyone else have this problem?
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #2 of 17 Old 08-14-2008, 04:08 PM
duct tape & zip ties
bigcountrysg's Avatar
You need more then a shift kit. Sounds more like the clutches are slipping from 2nd to 3rd. Which will cause the problem you are having. My suggestion have a trans shop run some diagnostic tests on your trans with there diagnostic computer. If you wait you will eventually have the O/D light start flashing at you.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 17 Old 08-14-2008, 04:11 PM
sldghamr's Avatar
i had similar problems years ago, went away when i changed out the fuel pump. you may a have a problem with fuel line pressure.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 17 Old 08-15-2008, 10:05 AM Thread Starter
hmm, so it sounds like its all over the place.
~Mike Lewis
265,000MI
post #5 of 17 Old 08-16-2008, 05:59 PM
I had something happen like that before in my BMW. Ended up that the tranny wouldn't shift because it sensed the rear tires spinning slightly different. I had a flat and put the spare on and the spare being new and the other tire already lost some thread the car sensed that something wasn't right, like drifting or so, and therefor wouldn't shift.
1997 F350 Crew Cab Dually 2WD PSD 5 Speed Short Range Manual
3' downpipe, Kitty delete, DIY NAPA Filter Intake, Edge Evo Programer on Lvl 1 for MPG
stinky is offline
post #6 of 17 Old 08-16-2008, 06:00 PM
sldghamr's Avatar
never heard that explanation before.
sldghamr is offline
post #7 of 17 Old 08-16-2008, 06:12 PM
Shaking the Bush Boss
CHUCK's Avatar
could be the speed sensor, more than likley it the trans. Is the od light flashing?
Chuck
CHUCK is offline
post #8 of 17 Old 08-16-2008, 06:15 PM Thread Starter
no light. But if i get on it, it locks up, then shifts.
~Mike Lewis
265,000MI
post #9 of 17 Old 08-16-2008, 06:40 PM
CHUCK's Avatar
might ought to have the codes pulled. I sheared of the splines on the input shaft, nothing ever acted up.
Chuck
CHUCK is offline
post #10 of 17 Old 08-16-2008, 06:42 PM
One more possibility is metal is being lost from the pump in the transmission, and getting into the valve body of the transmission. When was the last time the fluid and filter were changed in the transmission?
Diesel Monkey is offline
