How do i remove my center pins? - Ford Powerstroke Diesel Forum
Old 08-14-2008, 01:54 PM
im installing add a leafs in my front and the center pins have a nut on one side and the other side is a cone shape no way to hold it or slip a wrench on there. so how do i get them out?
Old 08-14-2008, 02:10 PM
Bump lol i need thisanswer soon. lol
Old 08-14-2008, 02:19 PM
duct tape & zip ties
Did you remove the leaf pack from the truck. Then remove the band clamps. That will release the tension on the pin. Word of advice put some c-clamps on the leaf pack before you remove those band clamps.
Old 08-14-2008, 02:33 PM
I always use an impact. Never had any problems.
Old 08-14-2008, 02:52 PM
Shaking the Bush Boss
Addding to the ?s.
How do you replace the leaf spring bushings in the frt springs?
Old 08-14-2008, 09:22 PM
yeah i had everything off but it just kept spinning so after like 30 minutes of trying different things i cut the nut off. i had new center pins anyway. lol.
Old 08-14-2008, 09:23 PM
Originally Posted by CHUCK View Post
Addding to the ?s.
Good luck with that. its probably spray it with some PB Blaster and push it out but idk.
Old 08-15-2008, 04:48 AM
I've never tried that but I'm sure your gonna need a press to get those bad boys outta there
