Oil leak from the front of motor - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-16-2013, 08:14 PM Thread Starter
stroke'n'drive's Avatar
i know another oil leak problem but I cant tell where its coming from and I wanted to see if its a common leak. Its leaking from the very front dripping from the crankshaft pulley so I cant tell if its the pulley where it seals to the front of the engine or something above it. theres no sign of leaks when looking from the top-down. if ya got any insight id greatly appreciate it
stroke'n'drive is offline
post #2 of 5 Old 11-17-2013, 04:45 AM
PSDTV21's Avatar
Could be a lpop seal. There is one where the pump mounts to the timing cover and one where the shaft goes through it. Its just on the inside of it from the front
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 5 Old 11-26-2013, 07:10 AM
AIRBORNE STROKER's Avatar
Did you ever figure your leak out? I just notice the dreaded spot on the driveway and have a leak in the "same area." I still have to clean it and take a better look but I am thinking either front crankshaft seal or hoping that it is the oil pressure regulator o-ring. From my understanding neither of the two are terrible to fix but the front crankshaft seal requires a special tool which you can improvise but have to be really careful and you have to remove the fan, where as the oil press reg o-ring is right there in the open.
2005 F250 SRW CC SB
AIRBORNE STROKER is offline
post #4 of 5 Old 11-26-2013, 07:35 AM
Quoted: 4 Post(s)
High pressure oil rail plugs been a common leak here lately with mine.
1997 F-250 HD XLT CCSB 4x4, 7.3L PSD, ZF5, Dana 60
08+ diff cover, 33x12.50R20's on Moto Metal 962's
3" DP to 5" straight pipe, pyro & boost guage, HPx Line,
Edge Evo, CX Racing intercooler, 6.0L fan, 1.0 Housing,
SD pump, bowl delete E fuel, 4.10, EBPV delete and ped
LEDs and HIDs, Ranger shift knob, RiffRaff Billet wheel
Black, Tan interior.
38' Gooseneck Enclosed Car Hauler.
Mototime2000 is offline
post #5 of 5 Old 11-26-2013, 03:16 PM
Wow my bad, I must have been having a brain fart at work. Just noticed you have a 7.3.
2005 F250 SRW CC SB
