no brake or turn lights help please - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-16-2013, 11:29 AM Thread Starter
i have a 95 f350 crew cab dually i recently converted to 4wd
my problem is just yesterday i lost turn signals and brake lights but have running lights.
all my fuses are good my lights go off the same light because i have a flat bed my wiring is all good the turn lights on the dash do not come on i put a new multifunction switch on and still have nothing any idea what it could be sorry about my typing
smforever is offline
post #2 of 6 Old 11-16-2013, 03:43 PM
Vicmillon's Avatar
Quoted: 2 Post(s)
I had a similar problem that was a loose cable on the brake pedal.
ABS light came on?
Manual or auto? Can you start the truck and shift into D?
Vicmillon is offline
post #3 of 6 Old 11-16-2013, 04:06 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Multi function switch aka blinker switch! Problem solved!
2000-7.3L is offline
post #4 of 6 Old 11-16-2013, 05:20 PM Thread Starter
ABS light came on. I switched the multifunction switch all connectors are hooked up ABS light is off i have brake lights but still no turn signals i can start the truck and yes because its a 5 speed.
post #5 of 6 Old 11-17-2013, 09:15 AM
Vicmillon's Avatar
Quoted: 2 Post(s)
Did you check fuses on engine box and driver panel?
post #6 of 6 Old 11-17-2013, 04:40 PM Thread Starter
yes the fuses were checked I still only have stop and running lights no turn lights and no turn lights on the dash
