exhaust leak? or not?
when im driveing my truck and give it gas it ticks real bad almost like a exhaust leak,
it did it before my stacks and now worse sence the stacks ![]() its all strait pipe and stock dp. is this normal? i was thinking maby a manafold? or dp??? |
sounds like manifold donuts
what kinda trouble would that be to fix?
bumpin it on up
Yeah most likely the exhuast up pipe doughnts are leaking. Open your hood. Look at your firewall, see if you have any black soot build up on the firewall.
looks like a little biuld up
I would check to make sure you do not have any clamps loose or hitting anything. TurboSevenThree had the same thing, ended up having an exhaust hanger hitting the frame of the truck. |
this one is buy the turbo
