What is this fluid leaking?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-07-2013, 05:27 AM Thread Starter
Cranked my truck this morning and let it warm up for probably 10 minutes then came outside and saw a big puddle underneath it. Probably 3 feet long and 2 wide, was coming out of the plate that's behind the oil pan towards the back of the truck. Fluid is clear, real gritty like oil and smells like gas. I'm thinking it may be brake fluid because my brakes have really became un-responsive in the last week. But what stumps me is where the leak is dripping from. After I noticed the leak I was in a hurry so I backed my truck up about 20 feet to get it out of the way then killed it. The entire time the truck was cranked that fluid came out of the plate behind the oil pan. As soon as I killed it the leak stopped. Any suggests to what it is the location of where it's touching the ground from confuses me especially since it smelled like gas too, was in a hurry so took the other truck and left so couldn't get a look under the hood or pictures. All I saw was it's leaking from the circular plate behind the oil pan. It's a 96 f350 5 speed
96 7.3 powerstroke, 4.10 gears, 5 speed f350 single cab dually, 3in downpipe from turbo, cat delete and straight piped-SOLD
2001 dodge 2500 2wd auto
7.3kid is offline
post #2 of 12 Old 11-07-2013, 05:50 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
If its brake fluid it is probably coming from the clutch slave cylinder getting ready to go out. My slave just went out in my ranger like this last week.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #3 of 12 Old 11-07-2013, 05:53 AM Thread Starter
How hard do you think it is to replace it? I probably don't know enough to replace it, but wonder what it'd run to replace with labor?
7.3kid is offline
post #4 of 12 Old 11-07-2013, 06:14 AM
Quoted: 4 Post(s)
Idk, I've never worked on a manual in these trucks. I've always had automatics.
I'd assume its an internal slave, of which requires dropping the Tranny to replace it since its right on the input shaft behind the clutch
Brett
post #5 of 12 Old 11-07-2013, 06:26 AM Thread Starter
Crap ok, thanks for the help! Think I should replace anything else while the trans is down?
7.3kid is offline
post #6 of 12 Old 11-07-2013, 07:31 AM
usteffenhagen's Avatar
Just look at your clutch to make sure nothing is worn down. You might want to get that whatever type of clutch disc if yours is stock. I'm sure someone will chime in with what it is
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #7 of 12 Old 11-07-2013, 07:46 AM
66Bronco's Avatar
These slave cylinders are external btw.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #8 of 12 Old 11-07-2013, 11:30 AM
Quoted: 53 Post(s)
Probably fuel. Did you look in the engine valley?
If the clutch is operating properly, it's NOT clutch hydraulic fluid. If it leaked that much, your pedal would be on the floor with no action. And it wouldn't leak/stop with the running/stopping of the engine.
Put some white cardboard underneath the truck and run it. Check the color of the leaking fluid.
madpogue is offline
post #9 of 12 Old 11-07-2013, 05:54 PM Thread Starter
There she goes
7.3kid is offline
post #10 of 12 Old 11-07-2013, 06:03 PM Thread Starter
Sorry guys didnt check forum til now, it was brake fluid for sure, I'm not sure for what reason I thought it smelled like gas. It was the clutch slave cylinder, I looked up under the truck and yep, thats where the leak is coming from. As the wrecker pulled it up on it poured out a ton more brake fluid... Also when I came back home yep it had a puddle under it of more brake fluid in the place I moved it to, just not as big as the other one where I had it running at, when dirtydiesel said that's probably what it was he was dead on. Back to the 24 valve for a little while haha
7.3kid is offline
