ICP Sensor - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-05-2013, 12:47 PM Thread Starter
ICP Sensor
My 95 Powerstroke acted like was starved for fuel. Ran scan and shows ICP not operating . Only shows 5 psi on fuel. Anyone know which part no. the sensor is ? Seems to be quite a few different ones and prices on ebay for this part. 95 7.3 powerstroke Auto, 4 WD. Thanks in advance
wrenchrangler is offline
post #2 of 9 Old 11-08-2013, 10:19 AM
97bluepowerstroke's Avatar
Idk the number. But if you have a international dealer near by I do remember it being cheaper from them then ford..
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
post #3 of 9 Old 11-10-2013, 07:33 PM
What would you describe as "your truck acting starved for fuel"? I am having a fuel issue on my 95 and I am looking for something related to my symptoms. Mine runs and idles rough, puffs more black smoke under acceleration than it should, and has a noticeable loss of power and mileage. I've put a fuel pump in, rebuilt fpr and fuel bowl, it's still not right. This is a pain. Any help from your experience would be greatly appreciated.
onomado is offline
post #4 of 9 Old 11-11-2013, 05:23 AM
I know the icp can make a idle rough. U can always unpplug your icp sensor.. se if it runs differ.t.. it kinda goes into a safe mode.. if it runs normal that way id reolace the sensor.. if its not that you could have a bad or dirty injector or bad orings on them
post #5 of 9 Old 11-11-2013, 07:46 AM
Would it cause the other things I mentioned as well, I. E. Loss of power, extra smoke, poor mileage?
onomado is offline
post #6 of 9 Old 11-11-2013, 07:56 AM
It is pissible. The icp comtrols the pressure to the injectors.. if its messed up itll over or defuel. When mine messed up It would make my truck accelerate n slow down on its own now and then while driving
post #7 of 9 Old 11-12-2013, 06:57 PM
kkbodyshop's Avatar
the plug on the icp sensor go's bad also
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #8 of 9 Old 11-13-2013, 05:29 AM Thread Starter
Found the part for 94-95 PSD #F4TZ9F838A. Prices online vary from $100-$500. Ricart , my local Ford dealer where I purchased this truck new,has OEM for $150 so am going that route. Found better prices and availability of newer ICP #F6TZ9F838A, but am told they will work and others say they won't. New ?? Will they swap out and work? Is anything different besides the pin material which I can remedy with dielectric grease.
post #9 of 9 Old 11-13-2013, 06:37 AM
Not sure I havnt heard about the new being better or worse. My ire went bad I replaced it with wire and plug out of a 7.3 school bus with no probs... the sensor itself is still factory. And I have no issues. You said ricart... thats in columbus right? There should be a ih truck store up there.
