96 7.3 f250 crank but no start - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-31-2013, 12:29 PM Thread Starter
hey i need some help gettin my truck back on the road i was driving and it hiccuped and died on me i cant seem to get it started again it cranks like normal but wont fire no smoke comes out the tail pipe i took apart the lift pump and cleaned some junk on the screen into the fuel bowl i changed the csp sensor already and im really at a loss i aint the most knowlegable mechanic but i can fix it if i get the information
agcoman23 is offline
post #2 of 19 Old 10-31-2013, 12:48 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Check this out, it may help you Diagnosing a 7.3 no start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 19 Old 10-31-2013, 01:14 PM Thread Starter
thanks that does help would a idm in a 7.3 older than 94 still work for my 96?
post #4 of 19 Old 10-31-2013, 01:15 PM Thread Starter
and do you have any pictures to help me find the idm....i have no clue where it is
post #5 of 19 Old 10-31-2013, 01:20 PM
Chapter Director
Quoted: 5 Post(s)
No theres no IDMs in anything older than 94.5 7.3. Any IDMs from 94.5 to 2003 7.3 will work.
Its on the drivers side fender wall right next to the distribution box and brake booster. Its a gray box about 7 x 5 x 2 with a big connector on it held by 3 long bolts to the fender wall
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 19 Old 10-31-2013, 01:21 PM Thread Starter
okay thank you again
post #7 of 19 Old 10-31-2013, 01:22 PM Thread Starter
is there any other way to check it besides just swappin it with another?
post #8 of 19 Old 10-31-2013, 01:25 PM
Chapter Director
Quoted: 5 Post(s)
Not any easy ways other than testing each pin(like 32 of them). You could take it out and give it a gentle shake and if you hear anything rattling it would be a prime candidate but that is by no means a sure fire test. Honestly if i were you you need to test fuel pressure and oil pressure first and do what i stated in that thread from beginning to end. IDMs dont tend to fail super often like some other things in the truck.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 19 Old 10-31-2013, 01:28 PM Thread Starter
i checked the oil level in the hpop its about a 1/2 inch from the top i also tested the shrader valve and it tested 37psi while cranking no fuses are blown and ive also deleted the fuel bowl heater so thats why i was jumping to the idm
post #10 of 19 Old 10-31-2013, 03:19 PM
Chapter Director
Quoted: 5 Post(s)
Well you need to test the oil PRESSURE too. Try unplugging the icp sensor and try starting it like that.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
