1 click, no start, starter tested good - Ford Powerstroke Diesel Forum
post #1 of 29 Old 07-26-2008, 10:43 AM Thread Starter
Cark's Avatar
Send a message via AIM to Cark
So the title pretty much says it. It's a 95, yesterday went out for work and it clicked, then took and second, then started fine. Got out of work yesterday and it wouldn't start, kept trying for maybe 5 minutes, just kept getting the 1 click, then finally it started right up. Stopped and got fuel, made the mistake of shutting it off, but it fired right back up no prob at all. Now, all I'm getting is the 1 click. I pulled the starter and took it to get tested, and it tested out fine. So I reinstalled and tried again, still just getting the 1 click. Does this mean a bad solenoid on the fender? Or maybe it's the wire? We did have about 5" of rain here over the past couple days, thought maybe that was something to do with it. Anyway, just looking for some advice, thanks guys!
'03 SAAB 9-5 Aero Wagon 5-spd - Stg 1
95 350 Crew long box - Sold
Cark is offline
post #2 of 29 Old 07-26-2008, 10:54 AM
sldghamr's Avatar
bad batteries??
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 29 Old 07-26-2008, 10:56 AM Thread Starter
Cark's Avatar
no, batteries look good, even when the key is in the start position my volt meter shows 12+ volts
Cark is offline
post #4 of 29 Old 07-26-2008, 11:00 AM
PIPE HITTER
gcop's Avatar
did you try to jump the solonoid?
"Life is hard, it's even harder when you are stupid"
gcop is offline
post #5 of 29 Old 07-26-2008, 11:01 AM Thread Starter
Cark's Avatar
I didn't yet, not exactly clear on how to go about doing that. Am I jumping the solenoid on the starter or the one on the fender?
Cark is offline
post #6 of 29 Old 07-26-2008, 11:11 AM
PIPE HITTER
gcop's Avatar
fender......
gcop is offline
post #7 of 29 Old 07-26-2008, 11:13 AM Thread Starter
Cark's Avatar
ok... so how do i do it? Just use a screwdriver or wrench and bridge the two terminals? Does the key need to be on or anything? What result should I be looking for?
Cark is offline
post #8 of 29 Old 07-26-2008, 11:17 AM
PIPE HITTER
gcop's Avatar
IN PARK,e-bake on ( just to be safe ) so yes jumper with a screwdriver, don't touch the screwdriver the truck should crank and start, if you have the key turned to the "on" position.
gcop is offline
post #9 of 29 Old 07-26-2008, 11:20 AM Thread Starter
Cark's Avatar
i'll try it out as soon as i finish this sub i'm eating for lunch. But how do you expect me to use the driver to jump the connections without touching it? Just wedge it in there and then turn the key? or turn the key then throw the driver in there? I've been electrocuted before, if I can avoid doing it again that would be great :-) And if that doesn't work then I assume that means it's the wire going to the starter itself?
Cark is offline
post #10 of 29 Old 07-26-2008, 11:24 AM
PIPE HITTER
gcop's Avatar
sorry, don't touch the METAL part of the screwdriver, my fault.......
So, PARK, E-brake, key to "on"...then use the screwdriver to jump the 2 posts the truck sould crank and start.
gcop is offline
