Power steering pump - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-28-2013, 04:02 PM Thread Starter
Power steering pump
Hey y'all, yeah I'm a newbie here...
My rig is pretty stock 96 F350 and developed
A loud knock last Friday. I pinpointed to
the PS pump. By the time I got home slowing
to a stop it sounded like a coffee can full of
marbles. Under power it didn't make the knock.
When I held the pressure hose it was like
the thing was dead heading instead of flowing.
I replaced the pump Saturday and ran it Sat/Sun
All seemed good, until this morning. I have the
same issues u had last week. Could I be getting
contamination from the steering gear; like
Pcs of metal??? Hate to replace another pump
and get same results. Thanks for any ideas
Az SON is offline
post #2 of 9 Old 10-28-2013, 06:36 PM
Quoted: 48 Post(s)
How did the fluid look in the old pump?
You did refill it with ATF, right?
madpogue is offline
post #3 of 9 Old 10-28-2013, 08:12 PM Thread Starter
Yes replaced w ATF, old fluid dark red. After looking and listening more this evening I'm leaning more towards a pulley? Heck idk, tomorrow I'll light it off w/o the belt and start from there. At idle it and coming off of the accelerator is when it sounds like a spoon is in the garbage disposal. Increase rpm and it stops. Def coming from front of motor and on the topside. Idk if it's the PS pump....any input is appreciated
Az SON is offline
post #4 of 9 Old 10-28-2013, 08:25 PM
Quoted: 48 Post(s)
Are you sure it's not just a weak tensioner spring, and thus the belt flapping?
madpogue is offline
post #5 of 9 Old 10-28-2013, 09:02 PM Thread Starter
I looked at the tension and thought it strange to hop a bit. I went back through my paperwork and that part replaced before. Can't hurt to change it if it's weak
Az SON is offline
post #6 of 9 Old 10-29-2013, 08:07 PM Thread Starter
Ok so changed tensioner assembly and all was good until she warmed up, knocking and rattling again. To save me some piece of mind I pulled the belt and fired her up. Same knocking and rattling coming from between alternator and AC comp. chasing what seemed to be a simple issue and now it's internal...any thoughts?
Az SON is offline
post #7 of 9 Old 10-29-2013, 08:33 PM
Quoted: 770 Post(s)
HPOP or cam gear
Corey@CNCFAB is offline
post #8 of 9 Old 10-29-2013, 08:36 PM Thread Starter
How can I confirm which is the culprit? As stated before only knocks at idle, decelerating. Does not knock accelerating or under load
Az SON is offline
post #9 of 9 Old 11-04-2013, 02:33 AM
Quoted: 770 Post(s)
Remove the HPOP gear access cover on the front of the engine. The one that your EBPS bracket is also attached to.
