Brake line question - Ford Powerstroke Diesel Forum
Old 07-23-2008, 04:25 PM
Brake line question
I have pretty much finished with getting my Dana 60 under my pickup.
It looks like I will need longer brake lines. My question is what brake lines do I order since the axle is a 1989 KP Dana 60 and my pickup is a 1996.
I'm sure someone has run into this...so I'm looking at what you used/ordered.
Thanks,
Old 07-23-2008, 05:21 PM
Try your local parts store, a 96 F350 brakehose should work just fine.
Old 07-23-2008, 05:29 PM
try bending your own get the line from the parts store
Old 07-23-2008, 05:54 PM
well I already ordered the wrong ones I think. I ordered brake lines for a 89 F350 thinking that they would be the same where they mount on the frame.
Would you just return these and try something else or is there something I can do to these (ie put this t-fitting in the brake line somehow?)
here is the difference...
frame mount end:
caliper mount end:
