Breaks still going down! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-23-2013, 07:49 AM Thread Starter
I did a complete over haul (I think) on my breaking system, change out the front an rear with all new hard ware! Yes I am stopping but when I sit I feel ,the break pedal goes down , plus my ABS light is still on ! Please I know am going to get the help like I always do here , what am I over looking or did not do ?
islandpower is offline
post #2 of 3 Old 10-23-2013, 09:38 AM
Quoted: 43 Post(s)
Did you bench bleed the master cylinder before installing it? Did you bleed all the underside points in the reverse order of distance from the master cylinder (RR, LR, ABS valve, RF, LF)? If not, you have air in the system.
madpogue is offline
post #3 of 3 Old 10-23-2013, 10:11 AM
Mine did that and it was the vacuum pump. Easy to change, front drivers side of the motor.
1996 F-350 Crew, Long Bed
injun46 is offline
