HELP!! my truck did something weird!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-19-2013, 10:27 AM Thread Starter
Quoted: 4 Post(s)
ok i just picked up a 96 f350 crew cab 4x4 with a auto trans it runs fine and every thing but the other day i was driving it and the check engine light came on and the gas pedal was like cutting out not working and the truck was shifting super HARD!! then the light turned off and it was fine?? also sometime when i drive it it shifts a little ruff only sometimes its got 300k with a supposed rebuilt transmission and motor.
mikemalo is offline
post #2 of 4 Old 10-21-2013, 06:40 PM Thread Starter
Quoted: 4 Post(s)
ok i got a better scanner came up with 3 codes p0603 KAM error, p0221 throttle/pedal position switch B circuit range/preformance, p0476 exhaust pressure control valve/ preformance. i just erased all the codes and took it around the block and barley made it home felt like the truck was running out of fuel/missing idk but i barly got back home and the volt meter was way low???? please help o and it still does the check engine light/ loss of gas pedal and super hard shifts every once and a whyle.... i really need help
mikemalo is offline
post #3 of 4 Old 01-11-2014, 07:02 AM
79 toy's Avatar
My 2002 is doing the no throttle and check engine light comes on I have not checked codes but think it might be my tps. Have you had any luck fixing yours?
79 toy is offline
post #4 of 4 Old 01-13-2014, 10:14 AM
97bluepowerstroke's Avatar
Could be a icp sensor or wire.. also if its tps sensor its in back od your pedal
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
