What to do next? Injectors - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-18-2013, 11:02 AM Thread Starter
KS_
Quoted: 22 Post(s)
I just ohm tested the my injectors because the truck just doesn't seem to be running like it used to, on the one of the four sets, I only tested two sets so far because its too much work for how sore I am.. . But on the one set I pulled 4.3 ohms and on the injector closest to the firewall I pulled 7.4. What do I do from here, this is pretty new to me
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 7 Old 10-18-2013, 05:11 PM
Spud Monkey's Avatar
Well if it's the one in your picture of your signature with 550k miles and those are injectors from factory I would imagine it's time to change them.
Spud Monkey is offline
post #3 of 7 Old 10-18-2013, 05:15 PM Thread Starter
KS_
Quoted: 22 Post(s)
Lol it is, but that's probably true. Just a lot of money for a college kid, just trying to see what can be done so that I can make them last until the money is here. Until summer I'm liven on my saved money
KS_ is offline
post #4 of 7 Old 10-18-2013, 05:27 PM
Could always look into getting them rebuilt. Much cheaper than buying new.
7.3l DRW F350 4x4. stock, with exception of Airbags on rear, bilstein all around and 26k 5th wheel hitch. K&N filter for good measure.
dont try this at home kids!
Unclebobsuncle is offline
post #5 of 7 Old 10-18-2013, 05:32 PM Thread Starter
KS_
Quoted: 22 Post(s)
Anywhere that'd rebuild them to stage ones for not much more, I planned on upgrading anyway one day? I just know they are like $1200 new, that's if you give them cores..
KS_ is offline
post #6 of 7 Old 10-18-2013, 05:40 PM
I have seen rebuild kits for pre 99 7.3 that increases flow to 160cc. But I have no idea how good they are or anything. Sure someone here done it though.
post #7 of 7 Old 10-18-2013, 05:45 PM Thread Starter
KS_
Quoted: 22 Post(s)
Ill try and do some research on that. Thanks. I miss my summer job.. minimum wage sucks :thumbdown:
KS_ is offline
