Fuel connection at fuel tank - Ford Powerstroke Diesel Forum
Old 07-09-2008, 04:51 PM
1996 F-250, I am trying to remove a fuel line from the fuel tank, released the clip and can't seem to get the hose off. I sprayed it with a little Triflow, it will spin but not remove. What is the magic for the Ford connector?
Thanks
Old 07-09-2008, 05:53 PM
Bumpity bump
Old 07-09-2008, 05:56 PM
What kinda connector did you remove?
Some of the newer vehicles require a special tool to release a spring clamp that is on the inside of the connection. They are designed to handle alot of pressure so pulling harder won't work.
Old 07-09-2008, 06:23 PM
There is a slight leak on the 3/8" line that connects on the top of the front fuel tank on our 1996 F250. I am trying to remove the line from the fuel tank to the front/rear fuel valve.
Thanks for any help.
