Bogging out - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-11-2013, 01:14 PM Thread Starter
Bogging out
Yesterday I was driving to a job site about mid day and my truck lost pretty much all power. Engine sounded like it was bogging out and my engine light came on. I let go of the gas and it a couple seconds later it went back to normal and the light went off. It did it again about 5 minutes later and then ran fine for the rest of the day. It did it again once this morning and then ran fine again. The engine light doesnt stay on so I can't run any codes. Anybody come across this problem before? I have a 97' 250, 4x4, automatic, ECLB.
Dansox is offline
post #2 of 3 Old 10-11-2013, 01:43 PM
sgt dave's Avatar
Quoted: 3 Post(s)
engine light does not have to be on to read a code. codes are stored so you can retrieve it. sounds like a hpop pump issue
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 3 Old 10-11-2013, 06:30 PM
Quoted: 43 Post(s)
If letting go of the pedal and pushing it again makes it go away, the idle switch is a prime suspect. Does your scanner also read live data? If so, you could set it up to read the state of the switch, and just drive it that way for a while. Then next time "it happens", keep your foot ON the go-pedal, and see if the PCM still says the switch is closed.
madpogue is offline
