No brake lights - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-10-2013, 01:34 PM Thread Starter
Remington11577's Avatar
No brake lights
So I have no power to fuse 13 no brake light and no flasher and won't shift out of park unless key is in first position helppp and abs flashing all fuses are good
Remington11577 is offline
post #2 of 7 Old 10-10-2013, 03:20 PM Thread Starter
We'll going to run a power wire to my brake switch unless there are any other ideas with a 15amp fuse but which wire on the boo switch?? Is this going to affect any other systems (abs, trans,)???
post #3 of 7 Old 10-10-2013, 10:15 PM Thread Starter
We'll it worked problems gone
post #4 of 7 Old 10-11-2013, 01:27 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You must of have had a short in the wiring... Make sure to cut the old wire out. If you don't and it is shorting out, now that that wire is powered from a different source you will have a draw on the batteries. Hopefully that makes sense.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 7 Old 10-11-2013, 05:23 PM
Quoted: 58 Post(s)
Is that fuse 13 on the interior box? There's also a fuse 13 (50A maxifuse) in the underhood box, which happens to energize fuse 13 on the interior box. Did you check both?
madpogue is offline
post #6 of 7 Old 10-12-2013, 11:19 AM Thread Starter
yes all the underhood fuses are good
post #7 of 7 Old 10-12-2013, 03:57 PM
Quoted: 58 Post(s)
See if you have power going into (and coming out of) fuse 13 under the hood. If you do, then the break is between that fuse and fuse 13 in the interior box.
madpogue is offline
