Occasional starting issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-02-2013, 07:20 AM Thread Starter
I've owned this truck for a few months now and occasionally I have starting issues. I say occasionally because it's only happened twice, with yesterday being one of them.
The first time a few weeks back was at home. I turned the key and waited for the "wait to start" light to go off. Soon as it went out, I turned the key to start but nothing. It didn't even crank over or anything. I immediately thought that maybe the battery was dead, but decided to cycle it a few more times. After the third time it cranked over and started without any issues.
Last night it happened after I drove it for a while. I was in the store for no more than 15 mins and then tried to start it. The exact same thing occurred where I had to cycle the key a few times before it would crank over. When it did finally crank over, the motor started right away just like last time.
Any ideas as to what would cause this to happen?
DChalue413 is offline
post #2 of 8 Old 10-02-2013, 10:42 AM
Quoted: 43 Post(s)
Automatic or manual transmission?
madpogue is offline
post #3 of 8 Old 10-02-2013, 02:30 PM Thread Starter
It's an automatic.
post #4 of 8 Old 10-02-2013, 03:10 PM
Quoted: 43 Post(s)
Try moving the shifter around next time it happens. Also try starting in Neutral, and try moving the shifter around the Neutral position as you're holding the key.
Are you hearing any click sound under the hood when you turn the key and this happens? Not the big "click" of the glow plug relay when you turn the key to RUN, but listen for a click of the starter relay when you turn the key to START.
madpogue is offline
post #5 of 8 Old 10-10-2013, 03:39 PM
I just had this happen too!
I had the same problem..... my 1995 7.3 PSD with automatic transmission would occasionally not start..... same as you described. I'd turn the key, and nothing..... then a few moments later, I'd try again, and it'd start. I was pretty sure it was the Transmission Range Switch that needed adjustment so I adjusted it, but the problem still occurred randomly. Then, the problem started to get progressively worse. I was ready to put in a new starter, thinking the solenoid was on the starter. Before I did that, I put a tester on the switched line that goes to the starter, and discovered that the ignition switched wire wasn't getting 12V when the key was turned to "START". Then I googled "Powerstroke Starter Solenoid", and learned that there is also one on the PS side fender. Before I did anything else, I tested that solenoid, and sure enough, that was the problem. I bought a new one for $24 at O'Reilly Auto Parts and put it in last night, which seems to have taken care of the problem!
My symptoms were identical to yours, and I bet your solution is going to be the same as mine! Test the starter solenoid with a 12V tester (don't be fooled if it is still clicking - mine was clicking, but wasn't closing the contacts!) to see if the power is passing through to the wire that goes to the starter motor
Hope it helps!
cason234
1995 CCLB 2WD 7.3PSD E4OD, 4.10 DRW 155K Miles
Lynden, WA
cason234 is offline
post #6 of 8 Old 10-10-2013, 07:01 PM Thread Starter
Thanks for the responses guys. cason234: I'll definitely test that solenoid tomorrow.
post #7 of 8 Old 10-11-2013, 08:08 AM
Let us know what you find! It'll be interesting to see if your problem was the same as mine
cason234
Lynden, WA
cason234 is offline
post #8 of 8 Old 12-04-2013, 10:42 AM
1982atm's Avatar
I was also having the same symptoms on my 2003 7.3 .. I had just put a new starter on it about a year ago and here recently it was doing the same as you describe. I took the starter off and had it tested at Autozone. It tested good so i pt it back on ,, it started 4 times in a row then quit working again . I took it back and demanded a replacement and so far it seems to be that was the prob... JUNKIE AUTOZONE PARTS GRRRR
New starter = fixed in my case
1982atm is offline
