97 starting issues hot and cold - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-28-2013, 06:45 PM Thread Starter
i have a 97 7.3L 5 spd manual "160000mil" with a swamps tuned Ts chip that iv had for the last 40k miles.Over the last few months it has become harder and harder to start. It began with only giving me trouble one the first start of the day but now it is doing it all the time. I have resorted to rolling it down my drive to start it and it fires as soon as i pop the clutch and runs fine.Once i turn off and try to restart it takes several trys most ending with a short fire and then the starter disenguages like it usually would when it starts.Once it starts correctly it runs fine. I have changed the fuel filter and oil with no change.Any sudgestions would be greatly apprisiated
sexton177 is offline
post #2 of 5 Old 09-28-2013, 06:54 PM
Quoted: 5 Post(s)
Are the batteries and starter good?
Does it start if you plug it in for a few hours?
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 5 Old 09-28-2013, 07:29 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
can you put an AE on it to see what the high pressure oil is when starting. could be hpop but most likely worn injectors.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #4 of 5 Old 09-29-2013, 09:52 AM
Quoted: 43 Post(s)
Have you removed the chip?
madpogue is offline
post #5 of 5 Old 09-29-2013, 12:17 PM
m j
glow plugs working? should be able to see that on the volt gauge.
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
