transmission leak - Ford Powerstroke Diesel Forum
post #1 of 31 Old 09-25-2013, 07:16 AM Thread Starter
transmission leak
Hey guys I have a 96 f350 dually, 5 speed single cab with 257,000 miles on it and today I got up underneath the truck after I got to school and saw red drips coming down, not a lot of fluid but no gushing out, in about an hour or two I'll be able to go back outside to it and look and see how much bigger the puddle has gotten. (Was no puddle at all when I left but i ran my finger on the bottom of the pan to the corner because it had a drop about to fall and it was red so that's why I think its transmission fluid) I need to drive it another 20 miles or so today. Do you guys think it'll be fine to drive it? Im not sure on what's really what on this truck but I have a good idea because I've been reading a bunch of stuff on this website that everybody's put on it helping me to learn. I'm not sure if I worded this good enough or anything like that, if you guys need more details I'll definitely give them to y'all! Not sure what to do, but I'm gonna get up under it in around an hour or two and I'll look around and try and find where the leak is at. Anything else I should do?
96 7.3 powerstroke, 4.10 gears, 5 speed f350 single cab dually, 3in downpipe from turbo, cat delete and straight piped-SOLD
2001 dodge 2500 2wd auto
7.3kid is offline
post #2 of 31 Old 09-25-2013, 12:59 PM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
Generally speaking, where is it leaking from, the flywheel inspection cover on the front of the trans or at the rear near the driveshaft yoke? If it was just a few drips and it has only started recently, you should be OK to drive it 20 miles. Remove the inspection cover and check inside the bellhousing for leakage, check around the vent (if you can find it on top), around the shifter housing area, and the PTO covers on each side. Cheers!
Patrick Feeley is offline
post #3 of 31 Old 09-25-2013, 01:21 PM Thread Starter
Thanks! I took it and drove up to my dual credit mechanics class and I parked it and the shop and maybe 3 drops put a puddle about the size of a half dollar were left after we got done messing with it so its leaking only a little bit. Is it OK if you get cawk and seal it up that way? Because if so that's what we're gonna do tomorrow. I checked the fluid after my teacher showed me where the plug was and its OK, what type of trans fluid does it take if you don't mind me askin? I'll top it off after were done and I need to know what to buy. Thanks for the help!
7.3kid is offline
post #4 of 31 Old 09-25-2013, 07:36 PM
Quoted: 10 Post(s)
Did you figure out where it is leaking? You could reseal the PTO covers or the shifter housing if they happened to be leaking, but everything else is a seal (like on the input and output shafts). I had the rear yoke nut come loose on my 94 which caused a leak at the output shaft seal, but a new nut (its a one-time use only self-locker) and the leak stopped. The tranny will use a SYNTHETIC ATF. Don't caulk it unless that is what is called for! Cheers!
post #5 of 31 Old 09-25-2013, 07:54 PM Thread Starter
Its coming from the back of the trans, the plate up underneath is bent where the backside droops down and we just thought that was where it was coming from. Im not sure of what's what still so I can't really describe it very well. The plates held on by 2 screws I think is it OK to take that off? I was afraid some fluid would spew out if I dropped it, I checked the trans fluid and its good if I haven't already said that. So take that off and see if I can find the leak from up underneath that plate? (60-70% sure that's where the leaks coming from. Thanks for all the help!
7.3kid is offline
post #6 of 31 Old 09-25-2013, 07:56 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
At this point a picture is worth 1000 words. The only "plate" I know of is the trans mount?
Trucks and parts............
kanuck15 is offline
post #7 of 31 Old 09-25-2013, 08:01 PM Thread Starter
One second I took some pictures uploadin right now
7.3kid is offline
post #8 of 31 Old 09-25-2013, 08:02 PM
kanuck15's Avatar
Quoted: 10 Post(s)
alright. Soon as I see a pic I will probably be able to tell ya whats going on. Ive been all over these transmissions
kanuck15 is offline
post #9 of 31 Old 09-25-2013, 08:07 PM Thread Starter
[IMG][/IMG]
Can't see it real well it's not the pan I meant to take pictures of but of the pan right behind it(closer to the camera) sorry I didn't get real good pictures.
7.3kid is offline
post #10 of 31 Old 09-25-2013, 08:09 PM Thread Starter
Originally Posted by 7.3kid View Post
[IMG][/IMG]
Forgot this one... [IMG][/IMG] sorry!
7.3kid is offline
