Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Problem Forum
Old 06-22-2008, 07:18 PM
george.ratliff george.ratliff is offline
Water in Fuel start??
when i start my truck i get some low and high from the motor.
and the volts are going back and forth and my water in fuel light is dimming and coming strong and when it stops doing it, it runs fine, but when i make a right turn and ONLY a right turn my water in fuel light come's back on??
any one know what this could be??
Old 06-22-2008, 07:36 PM
bump anyone have any ideas??
Old 06-22-2008, 07:55 PM
anyone?
Old 06-22-2008, 08:16 PM
really? noone knows or has heard of this?
Old 07-04-2008, 09:47 AM
eagledieselmedic eagledieselmedic is offline
Have you tried opening the fuel filter drain valve? (located at the top of the engine, a yellow valve, only req. a quarter turn to open)
I cannot find the posting but there was a thread where someone described how to place a hose on the outlet port to keep the fuel from hitting the ground.
I had water in the fuel on a 96 e350 and had to leave the drain valve open, with a catch pan, and cranked over the engine and let it idle until the light goes out. Then closed it back up and have had no further problemswith water.
You can also add the proper amount of Power Service (avail at walmart and autozone). Run out the current tank of fuel, then replace the fuel filter (both if it has two).
Old 07-04-2008, 09:55 AM
!!!PainTrain!!! !!!PainTrain!!! is offline
TED NUGENT FOR PRESIDENT
My 05 would do this same exact thing, only on right hand turns. Ended draining the water seperator and replacing the fuel filter on the rail (below driver's door). After this the sporadic sputtering of the motor went away and so did the light.
Old 07-04-2008, 10:15 AM
Maintain Maintain is online now
13.0 @ 102
Send a message via AIM to Maintain
Just stick some hose on the tube and route it to a can.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
