U-Joint slop - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-20-2013, 12:31 PM Thread Starter
U-Joint slop
Still looking for an answer. Is this enough slop to creat noise or rattling when driving?
powerstroke814 is offline
post #2 of 5 Old 09-20-2013, 03:44 PM
Quoted: 50 Post(s)
Are you driving in 4HI on dry pavement? You're gonna get noise no matter what, and you're gonna "wind up" various parts of the driveline. Or are you hearing this while off-roading?
Edit - just noticed, this is a rehash of your other thread. The front driveshaft isn't even in play when you're cruising down the road in 2HI. If you're still hearing noise, it's in your REAR driveline.
madpogue is offline
post #3 of 5 Old 09-20-2013, 03:58 PM
gingerbredman00's Avatar
Garage
Check your sway bar end links.
gingerbredman00 is offline
post #4 of 5 Old 09-20-2013, 04:32 PM
Quoted: 50 Post(s)
What sway bar?
madpogue is offline
post #5 of 5 Old 09-20-2013, 09:04 PM Thread Starter
I just had the rear driveshaft balanced new carrier bearing and all new u joints. so i dont think it is that. yea what sway bar?
