'97 Powerstroke-blue gray smoke - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-19-2013, 02:43 AM Thread Starter
Need some help here.
This is my first diesel, so I'm out of my league.
Guy I bought the truck from said the previous owner had replaced the injectors with "bigger ones" and put a programmer on it (UTP box wired into a plug that is under the air cleaner)
A couple of weeks ago, I pulled my camper, seemed to do ok. Coming back empty-lots of blue smoke started coming out of my exhaust. Was told to check the turbo by seeing if the shaft would move on the intake side, and it had a good 1/4" play in it.
When I removed my old turbo, there was all kind of oil in the exhaust flange. Bought a reman turbo from Ron's turbo service. Installed it along with a new down pipe.
Still have smoke. Looks kind of gray when idling, blue when throttle is applied, and I swear I can smell diesel fuel. Truck doesn't seem to be running right either, whole truck shakes when idling.
Have I got a bad injector? Bad injector O-rings? Is that UTP programmer messing with me?
Please help!!!!!!!!!!!
jimcolyott is offline
post #2 of 2 Old 10-01-2013, 12:43 PM
quicknick106z's Avatar
Take the programmer off see what happens?
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
