Truck will NOT start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-13-2013, 07:47 AM Thread Starter
1997 f250 2wd. The truck has been acting up. After a late night at my buddies I went to start it and the truck tried to crank but sounded almost as if it hydro locked and all electrics shut off. Tried to throw it on the charger at max power and it would not even light up. After sitting a little while interior lights came on but the truck would just click from one of the solenoids under the hood and also from the fuse box. We swapped in a marine battery and had the charger on it still nothing. Finally after about 2 hours it cranked over and started randomly. Drove it fine for a week until I went to go to school and the truck went to crank and just stopped, killing all electrics in the truck. Spent the day with my brother trying to figure it out. Batteries tested fine, alternator was new 15,000 ago, and a new starter in march. I checked the bolts to the starter and one was a little loose. Tightened it and still nothing. So I took the starter out cleaned it up bench tested it on the ground. Everything spun freely and fine. After we bolted it back up it did another half crank and was dead again. Then I tried one more time and it started. I drove for 2 more days before I stopped by my moms shop and it did the same thing AGAIN. I went to auto zone and they gave me a new starter under warranty and swapped that out with the old one and still no avail I am really stumped. With the charger on the truck just clicks rapidly coming from the starter. ANY ideas will be helpful!
97_Stroked is offline
post #2 of 8 Old 09-13-2013, 07:58 AM
Quoted: 50 Post(s)
Did you isolate the batteries and _load_ test them?
How is the main cable, the one running between the two battery positives and to the starter main motor? How are the battery negative cables?
madpogue is offline
post #3 of 8 Old 09-13-2013, 08:26 AM Thread Starter
all of my terminals are complete junk, as far as the cables the are in decent shape
95 250 2 legger
zf5
all stock besides a stack
post #4 of 8 Old 09-13-2013, 09:53 AM
Quoted: 50 Post(s)
Um, fix that first.
madpogue is offline
post #5 of 8 Old 09-13-2013, 10:23 AM Thread Starter
I took the batteries to a shop to have them tested and they checked out. It is not the terminals that is the problem, although they are getting replaced. I need ideas on why this ol gal ain't cranking
95 250 2 legger
zf5
post #6 of 8 Old 09-17-2013, 10:14 AM Thread Starter
I replaced the fender mounted solenoid and still nothing... My brother seems to think it is a ground possibly? I have not replaced the terminals yet but i really do not think that is the problem because when i put it on the charger everything lights up but just clicks. It has a new starter, new fender mounted solenoid and i had the batteries tested at a shop. What is next on the list?
post #7 of 8 Old 09-17-2013, 12:27 PM
Quoted: 50 Post(s)
The charger is just providing secondary power to light up the accessories. Doesn't have nearly enough power to crank the starter. The truck WILL NOT start with bad terminal connections. Fix what you know is broke. The relay was probably fine.
madpogue is offline
post #8 of 8 Old 09-17-2013, 12:46 PM Thread Starter
Ok I will replace the terminals and possibly the batteries and get back to you!!
95 250 2 legger
zf5
Tags
7.3 , dead
