Loping idle issue help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-01-2013, 10:28 PM Thread Starter
Ok so I've been chasing this issue for a while now and I'm trying to get a for sure answer on what's wrong. It lopes on start up weather it's warmed up or cold it also does it when your driving but only if you pres the peddle a little bit but if you are half to full throttle it won't do it. The weird thing is the truck is not down on power has great oil pressure. I checked the EBP sencer by unplugging it then starting the truck and still the same. My only thought is that the IDM could be bad or the cam sencer is bad. Any other input on what could cause this problem would greatly be appreciated!
Obstroker95 is offline
post #2 of 5 Old 09-02-2013, 06:59 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Welcome!
Don't know if you have a 5-speed or automatic (filling out a signature line with truck and modification info is very helpful), but if you have an automatic does it do it if you start it in neutral? Cheers!
Patrick Feeley is offline
post #3 of 5 Old 09-02-2013, 09:35 AM Thread Starter
Originally Posted by Patrick Feeley View Post
Welcome!
It's actually my work truck, a rollback 5speed totally stock it has 243,000 miles on it
post #4 of 5 Old 09-02-2013, 07:50 PM
Quoted: 13 Post(s)
Try a CPS (get it from Ford or IH) since that is a cheap try. Otherwise, how's the fuel pressure at idle? Cheers!
post #5 of 5 Old 09-02-2013, 08:12 PM
Gaius's Avatar
Quoted: 43 Post(s)
Wouldn't a lope all of the time point to an oil problem or injectors?
I would either buy AE or have someone use a scan tool on it to see what the ICP and HPOP pressure is...
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
