HELP truck wont start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-01-2013, 02:20 PM Thread Starter
i own a 97 ford f250 7.3l diesel while driving the fuel filter light came on, and the engine started running rough, then started losing power, when pressing the gas pedal no acceleration, then stalls and will not start.
grovesoccer4 is offline
post #2 of 9 Old 09-03-2013, 06:08 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Don't mean this to belittle you but there is fuel in the bowl correct?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 9 Old 09-03-2013, 06:11 PM
jesilvas's Avatar
Quoted: 2 Post(s)
To add to that courteously, is there diesel in the tank?
Next thing, is fuel in the bowl.
Next, just go ahead and replace filter, drain water out.
Then you'll find out if your fuel pump is pumping or not.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 9 Old 09-03-2013, 07:31 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
You should also try switching fuel tanks (assuming there is fuel in it). Cheers!
Patrick Feeley is offline
post #5 of 9 Old 09-04-2013, 12:51 PM
Msp079's Avatar
Quoted: 52 Post(s)
Smile
I had the same thing happen to me with my 95 f350 diesel.....Happened on highway...Come to find out it was the solnoid sensor was smoked....
Also if it is still running rough, check the camshaft position sensor, berimetric sensor and back pressure sensor....
After I replaced the solnoid it would start when it wanted to so, come to find out the biggest thing was the camshaft sensor was way off...
Hope this helps, Let me know how things go.....
Msp079 is offline
post #6 of 9 Old 09-04-2013, 01:30 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What is the solenoid sensor?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 9 Old 09-04-2013, 01:32 PM
Ford7three's Avatar
If it triggered that light, more than likely something got sucked up into the filter housing and clogged it. I would swap the filter, make sure there is fuel in the tank and make sure there is no water in the housing.
Ford7three is offline
post #8 of 9 Old 09-04-2013, 02:17 PM
Msp079's Avatar
Quoted: 52 Post(s)
What I ment to say is the Solenoid...and it deals with the transmission.
Msp079 is offline
post #9 of 9 Old 09-04-2013, 02:38 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You mean the VSS?
4R100, 2wd
330,000 + miles
jesilvas is offline
