Cylinder 5&6 high to low side open! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-28-2013, 01:57 PM Thread Starter
ole96stroker's Avatar
Finally got to put my a scanner on my truck today and did a buzz test to see if it would do anything with my new injector's and got 5 and 6 cylinder high to low side open, Could anyone tell me what to look for and what to replace? My idm is new but is a reman to, I guess this may be the reason why it shaking awfully bad I would think. thanks!!!!
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 2 Old 08-28-2013, 03:38 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I would inspect all the UVCHs, valvecover gaskets, and external harness connections. You could also check the resistance of the solenoids by ohming between the middle pin and each adjacent pin (pin #3 to pin #2 an pin #3 to pin #4) and see if they are reading around 2-3 ohms. Cheers!
Patrick Feeley is offline
